Something I did recently (I don't know what to call it so Tutu Obsession it is):
http://soundclick.com/share?songid=6373073
Obsessive Loops
- BingoTheClowno
It's pleasant but the drums are too simplistic. They could use some accents and more syncopation and a couple more drum sounds. It would blend better if you used acoustic drum sounds instead of the electronic ones. A little but not too much bass would improve the percussion. The "do do do" sound bothers me because I've heard it before and it sticks in my head too much.
- BingoTheClowno
You are right on all points. I did not put too much effort into the drum track and it does sound mechanical, not natural. Although it is acoustic blended with some electronic samples (NI Battery). There is something about that "do do" pattern, it does bother me toobraincell wrote:It's pleasant but the drums are too simplistic. They could use some accents and more syncopation and a couple more drum sounds. It would blend better if you used acoustic drum sounds instead of the electronic ones. A little but not too much bass would improve the percussion. The "do do do" sound bothers me because I've heard it before and it sticks in my head too much.
Thanks.
Thanks Hubird.
