TziTzi V1.0
MCCY
TziTzi V1.0
Post by MCCY »
First step to my new-generation-dynamic enhancing.
Martin
EDIT:
- TsiTsi 2
- bugfix knob no4
- 4 x knob for modifying freq... First try understand all other knobs. default position is in the middle-position.
EDIT:
- version 1+ 2 were not sounding as they were supposed to be
- Hm, some internal values (the most important) got screwed up, now that should be fixed...
EDIT:
- black-knob-bug corrected
EDIT: V4
- other black knobs ;)
- softsat
- attention: as removing elements from dsp with 0-position of the knobs be aware of phase problems! Move the fader to position of the activated element, when deactivating the other...
EDIT V1.0
- interface overworked
- dsp-usage optimized
- dynamic behaviour added
MCCY
Post by MCCY »
Hope version 3 now sounds like I wanted it to... Some fixed values changed although being fixed - I hope this will work now... Tested it once, now I will do a second test.
MCCY
Post by MCCY »
Wow, yes, :D NOW I LIKE IT :D
MCCY
Post by MCCY »
Ah, the black knobs cause the problem. As long as you don't use them everything's fine.
Lima
Post by Lima »
MCCY wrote:Ah, the black knobs cause the problem. As long as you don't use them everything's fine.
So you could change their color to red :-D
katano
Post by katano »
aah, martin, you make me dizzy with your tsi-tsi!! :-) just downloaded the last version and it's already a new one there...
katano
Post by katano »
ah, a usable interface would be nice and some level meters ;-) anyway, will try it tonight...
kylie
Rank-o-phile
Post by kylie »
I have no real idea what it could do...
no labels for the knobs. martin, whaddaya up to? :)
-greetings, markus-
ps. circular devices are out. why not doing a triangular shape? :D
MCCY
Post by MCCY »
Heho, since I met those superkind & nice & freaky sc-guys at the messe I have 300%+ motivation and it seems some "groschen fielen Pfennigweise" - I have another breakthough today with compression-algorithms. While JuAnCo is sort of great I found building another one from scratch now much more defined and clear in the circuit. I needed a well defined compressor for another device I plan...
It seems as there has been taken a curtain from my eyes: maybe it's because of the thought that this platform is futureproved now which makes me think much clearer. Which makes me think: Yeah, every little thingy I build today will be usable the next 10 years!
I like annoying you with my GUIs, cause I have more and more the feeling, that I'm able to build great internals which need a bit contra in the GUI 8)
MCCY
Post by MCCY »
TziTzi is kind of an exiter. All 4 purple knobs are for adding high-frequency-content. The two faders morph between each pair of them. The black knobs make the freqencies shift (doesn't make too much sense in most cases).
I have a version 4 here with softclipping & minor improvements which makes perfect sense with that device, but I posted it just that you have a first impression what I'm about to build ...
Turn all purple knobs (except input) to 0%. Then test on vocals/mix/drums... which of the 4 pleases you the most.
MCCY
Post by MCCY »
Good idea. I will consider that!
kylie
Rank-o-phile
Post by kylie »
looking forward to see that :)
did you get some decent results with blender recently? I'd like to see some new knobs. rectangular, maybe... :)
MCCY
Post by MCCY »
V4 Maybe my last version as this was an experimental project (& yes, it has the most ugly GUI ever seen on this planet - I try to keep that avard on my side ;) ). I've gotten quite far with some really serious stuff...
FrancisHarmany
Post by FrancisHarmany »
MCCY wrote: I've gotten quite far with some really serious stuff...
Yes report on this please :lol:
YiannisK
Post by YiannisK »
You should call it Tzitziki ( Greek sauce usually with souvlaki) and put a souvlaki on the plate ( your GUI) :lol:
Just a joke no pun intended!
Sounds very crisp, thanks keep them coming now that you are inspired :wink:
MCCY
Post by MCCY »
UI optimized :D & DSP optimized TziTzi (you may call it "Tzitziki" as nickname ;) )
fra77x
Post by fra77x »
well the greek word for the mentioned sauce is Tzatziki. Tzitziki (cicala) is the summer incect that sings and sings until the night. Tzitziki is the opposite of the ant according to a popular story, in which the ant works the whole summer so to have a nice winter.
I personally prefer cicala sings and rest by the sea
YiannisK
Post by YiannisK »
Your right about that and it makes more sence than Tzatziki.
O Tzitzikas.
Hi frequency sounding insect.
I wonder what a sampled tzitzika woud sound like through MCCY'S Tzitzi? :lol:
To fra77x. I hope you understand my Grenglish
Yiasou Patrida, Pou eisai? Athina?
Ti kero exei ekei?
Grafies tragoudia yia kanena kalitexni, H asxolise mono me Synth Design?
Ego apo Thesalia (Karditsa) genimenos sto Kanada.
Zousa gia 12 xronia stin Athina kai douleba sta kentra me
Kourkouli, Elena Paparizou,Gonidi, kai se studio epeza se diskous.
khta to site mou na akousis kai mousiki Instrumental me gefsi Elliniki.
http://www.yianniskapoulas.com
Giasou file kai signomi yia to tharos pou eixa na se grapso prosopiko minima sta Ellinika. :)
Zito H Ellas
MCCY
Post by MCCY »
Wow, so I will definitively rename it, if that's O.K. for you. That's a really cool name for that device... purple Tzitziki sitting on a round of green grass and zirping in the highest tones... I have somewhere a Tzitziki-foto for the fader-knobs, maybe :lol: :lol: :lol:
