PsyQ
Music Manic
PsyQ
I've been using this quite a lot lately and can't tell you how great it works on certain things.
For instance it gives strings a real new life.
Does anyone know about the programming algorithms of this beauty?
Whoever developed it really knows about the ear.
borg
Yes, this is my most used device. It gives me the instant feeling I'm a pro sound engineer.
Mind you, I have never finished a real track in the last three years. I just start a project, sequence an idea into an acceptable track, put on PsyQ, like it, and few days later, or a month, I'll start something new.
I have more than 100 projects I need to finish and mix properly. Bur for now, PsyQ makes it all seem glued together pretty good already...
andy
the lunatics are in the hall
Lima
iskra
I like it, but one thing irritates me about it, it seems even with high eq section turned to zero/minimum it still has some effect boosting highs & there is no way to turn this off.
I use it on drums a lot (loops or midi programmed samples) & on mastering from time to time, but I find with mastering its not always of benefit, & sometimes even on low settings it gives a little too much of a sheen. I should add I use almost all electronic instruments, synths, occasional samples etc and no accoustic ones (except voice). I've found my best uses of it have been on individual elements in a mix, rather than in mastering.
What do you mostly use it for?
greenbluegold
I was recording some LPs onto my computer last night. I had to go through a mixing board in order to interface between the turn table and my scope card which impacted the sound in an appreciable way -- a little less focused, kinda muffled, boomier. I ran the signal though psyQ, and was amazed how it tightened up the sound.
arela
For turntable you can use Wolf's Phono PreAmp (a free device - thx wolf)
http://wolf-audio.com/wad/freebies/Entr ... reAmp.html
greenbluegold
- FrancisHarmany
borg
Music Manic
Agreed.
My ears were mixed out on my last recording.
I listened to fellow members the after a little sleep and went back using PsyQ, and a little less PCM91 on the drum mix and added PsyQ slightly.
The results were far from slight though.
This device can replace the frequencies lost during the conversion of mp3's also.
Another fine CW plug.
