1) you can load modular II/III modules into SDK projects
1 bis) ok, you probably already know this
but what about...
2) in the project tree, if you move "modular view" into the "panel" subtree, you will see (and can use) the modular module surface into the panel once you open it!
this goes directly to
3) you can load the modular II/III modules: SAMPLEPOOL, SAMPLEOSCILLATOR and then, form the surface, you can load samples into the pool, and then move the sample you have loaded into the sampleoscillator module.
in this way you can manage mono waves, and you don't have access to multisampling, but it's better than nothing!
moreover, you can load only the SAMPLEOSCILLATOR module, assign a button to the surface to the "Load sample" button of the module itself, and load the sample from the synth surface without having the modular view on the surface itself...
now, we'd need a stereo modular player, or a way to manage multisamples!
