what desktop resultion do you use for your DAW? poll
what desktop resolution do you use for your DAW system?
1024x768
4
9%
1280x1024
23
49%
1440x900
4
9%
1600x1200
7
15%
higher resolution 1920x... and so on
9
19%
Total votes: 47
hifiboom
Post by hifiboom »
I would be interested to know this.
in the special case that you`re using dual screen or triple screen combinations, please take the time and post a short reply, how many screens and @which resolutions.
Fluxpod
Post by Fluxpod »
1680x1050,1024x768,1024x768. 3 Screens.
1280-1024, two times (next graphic card will allow for higher values).
katano
Post by katano »
3 screens, 1680x1050, 1680x1050 and 1600x1200 (with matrox triplehead2go using only 2 screens for max resolution).
Screen 1 for Sequencer
Screen 2 for Scope Mixer
Screen 3 for Scope Effects/Mastering or Routing
Cheers
next to nothing
Post by next to nothing »
1680x1050
pollux
Post by pollux »
3 19" monitors: 1280 x 1024 each :D
Neutron
Post by Neutron »
2x 1680x1050
one is mostly for scope, and the other is mostly for the sequencer.
Lima
Post by Lima »
2 heads: 2 x 1280 x 1024
Herr Voigt
Post by Herr Voigt »
Same as Stardust and Lima.
Me$$iah
Post by Me$$iah »
stardust, Lima, Herr Voigt and me
Tho Im currently waiting for a pair of 24"w/s to arrive, I guess i'll go up in res then (if possible)
katano
Post by katano »
poor old stardusty, how about some glasses or contact lenses? :D
such a big screen with that resolution is completely waste of space for me...
katano
Post by katano »
well, errm, no, but solaris is the last plugin i didn't buy yet... you could also move closer to the screen ;-)
2x 1280x1024
hifiboom
Post by hifiboom »
actually 21" TFT normally has a bigger visible area than a 21" crt !
so 1600x1200 on a 21" tft may be quite viewable.
on my old Eizo 21" 1600x1200 is quite small, because it just has 19" visible diagonale.
but then again it has a very natural colour representation compared to the cheaper and mid-range TFT panels.
Sure this isn`t important for DAW tasks but maybe for other things... :wink:
I think it really depends on taste: I know many people that want big icons, personally I prefer small icons( higher resolution on smaller diagonale). I dream of a 24" running at 1920x1200.
kylie
Rank-o-phile
Post by kylie »
stardust wrote::lol: also correct I should get closer.
What hinders me is the lkeyboard and the midi keyboard between me and the LCD currently ;)
there are spring-equipped adjustable display arms with vesa standard mounting plates. enuff to get your display close to the nose... :wink:
-greetings, markus-
hifiboom
Post by hifiboom »
i have 30cm, :lol:
how much distance have you?
katano
Post by katano »
BTW solaris is maybe not the best example since there I only refer to the mod knobs and the switches.
Take a look at the new micro modules from Roy for the modular synth.
I always feel like having stubby fingers.
hmm, problem is the mouse thingie. if we had a cool scope controller, it wouldn't matter if the graphics were small, because one could then concentrate on the sound instead of the graphics!!
Soniccore: GIVE US A HW-CONTROLLER!!!
/off topic
kylie
Rank-o-phile
Post by kylie »
stardust wrote::lol: I was considering that, but does not work for 2 screens and needs the right mounting rack as well.
you can get them with more than one arms.
http://www.ergotron.com/Products/DeskMo ... fault.aspx
they have fixed (non-movable) stands as well, but that wouldn't solve your problem...
-greetings, markus-
katano
Post by katano »
cool though :)
no wonder you like small icons... :-)
50-60 is the standard, for example that's the distance my opticion takes for making decisions about my lenses (left eye a bit better focussed on close distances).
thanks for the link Kylie :-)
