my first try was a multi-gate module... i almost succeed, even in building the control surface, but there were somthing odd in the actual behaviour of the device... moreover yesterday evening it became very late and i interrupted my experiments...
but still i have some questions that i'd like to clarify...
first of all: i discovered that you can actually use the existing "stock" synths and FX from SFP and chain them to make a new device.
what i absolutely don't understand is if it is possible to gain access to the control surface... not to edit its appearence but to actually USE it!! if i connect the stock gate and eq and save a new device out of these, it works in the common SFP window, but i'm not able to edit the settings!
i even tried to insert them into the SDK module "blank effect" which has a blank surface, or to drag the SFL FX into the surface itself... but still i cannot gain access to the parameters once the new device is in the SFP window...
is this possible or it is forbidden and i should spend no time in using existing SFP devices, since they cannot be actively used??
the same is for modular II and III modules: i can drag/drop them into SDk and use the connections, but how can i then edit the knob values once i have exported the device??
using modular in the surface would permit, for example, to use the "mod waveplayer OSC" to build a simple sampler...
i don't know if you made this, but i copied all the DSP files from the SFP directory into the SDK one: in this way i can gain access, for example, to dynatube (which i own) atoms . there are indeed plenty of atoms to choose from... moreover, i also noticed a "akai sample playback module", but how can one actually LOAD a STS or akai program into it?!?
last one... i noticed there are some ".pep" script files, which appears into the file browser (even in the filter). they have intersting names... but are they available into the SDK!?
ok, for now it's all... i will have to do some more experiment!
thanks!
