As promised in another thread, here are some screen shots of our new and novative Multimode EQ ...
New algorythm, novative and very versatile : 11 Eq types ...
Peak
Low and High shelf,
Low and high pass,
4 band pass modes ...
2 notch modes ...
Build exclusively with stock math atoms from SDK and few C++ codes
How to "read" the following screen shots :
The original signal is a WHITE NOISE @ 0 dB (grey line in background)
analysis is taken from WAVELAB's FFT analyser -
X axys : 100 Hz to 20000 Hz
Y axys : from -30 dB to -100 dB
frequencies
- For an easiset way to understand these pictures, all shots are for a Frequency (FC) of 2000 hz
Q factors
- the upper and lower part of each picture are the maximum and minimum Q factor setting
Gain :
- cut means -12 dB
- boost means +12 dB
As you can easily understand ... we have prefered to post screen shots instead of mp3 ... just imagine listening to so much White noise equed ...
We are stil optimising some features and look for a great GUI, demos will be avaible "sooooon"
cheers
olive
