It seems that when I click on my control knobs they will quickly go to center position then back as I keep moving, how to stop this? The faders work fine but the knobs will center as soon as I start to move them.
thanks
little control problem
Jah Servant
Ok, here's what I have found, if I am using the movestyle where you click the knob and then move horizontally it seems to work good (movestyle 1 I think) but with any rotating style the knob seems to jump or want to always start from center (or reference center position first?). It'd be nice to fix this, help if you can.
Jah Servant
I am doing this but at all settings the knob wants to jump to center as soon as I start to move it, except for movestyle 1 but this doesn't allow you to rotate with your mouse, you move the mouse vertical for this, it's a small thing but I know that I should be able to rotate the mouse. I'll see what happens when I build a new device and see if things are different.
Jah Servant
