Cubase 3 locked up - Creamware cards unavailable
I was workin on a track in Cubase 3. After loading a plugin Cubase hangs. Then i had to reset my pc because ctrl-alt-del didn't work. When booted started Cubase again and my Creamware cards in Cubase are unavailable.. Not in device manager. But i can load files into Scope. I installed Asio4all and this program says: Beyond Logic. I un&reinstalled Cubase, disabled Creamware cards in device manager XP. Still no Creamware cards in Asio setup. XTC mode is off.. Now.. half an hour later i have Creamware play-rec 1&2 back in Asio setup. Don't know what to do! Cannot switch to Scope Asio driver in Cubase.. Asio Scope could not be initialized!
When your computer crashed you probably damaged some files, either try a system restore an asio file may have been damaged, or safer to just reinstall scope,and then cubase.I suspect that you think that asio4all will actually do something to help the situation unfortunately it won't.
good luck
good luck
Update: Installed my pc again, all new. installed scope, installed cubase. now i miss 6 outputs. I really don't know what to do. Are the cards broke?
- here the Cubase asio setup
- scope screen.JPG (209.31 KiB) Viewed 2915 times
- here all my settings
- scope screen 2.JPG (256.17 KiB) Viewed 2915 times
Your samplerate should be on master
- correct.JPG (65.07 KiB) Viewed 2895 times
well you can see that it's not syncronised can't you so obviously the platform won't make any sound, try it on master
what you see in the asio setup there are the WAVE drivers wich are used to sync the asio there not asio drivers.And I might add that if you don't put wave drivers in your project in to a mixer for example the asio driver can't sync to the scope drivers.you sync the asio setup to the internal soundcard I imagine.
