Best Old PC for Scope
Hello,
Since I miss my scope cards sadly, and since I wont upgrade my daw I need a second PC for my scope, and then hopefully in a configuration where there are fast grapahics and no IRQ problems - in fact the new pc would only house one scope card, no hard disk (boot over lan from my primary pc) no noisemakers, a retail PSU with deactivated fans etc, the pc will only run my scope card (6dsp probably) and do nothing else. Does anyone know a mainboard which can do this very well? I still have a 2400+ Athlon XP in the Socket A formfactor, maybe I can reuse this one with some old motherboard...
any suggestions for what (old) mobo or cpu I should take?
greets
Tom
greets
Tom
I have a Gigabyte GA946GMX-S2 with onboard Graphic, 10/100/1000 LAN that can take anything from a Celeron D to a Quadcore, socket 775.
I paid 65 Euro for the mobo, houses 2 Pulsar Ones under XP (yes, I eventually had to give in...), no problems.
you might as well get one of those Pentium 3 office boxes with an ASUS Tusl or Cusl mobo - there some Maxdata on eBay featuring that board which even come in a really excellent case for 50-80 Euro complete.
this is the Maxdata I mean - it's not always mentioned which chipset is inside.
These boxes have been sold with whatever was available, but as a corporate supplier Maxdata is a quality brand here in Germany.
I recently did just that - built an old pc for Scope only. I've been getting excellent results with an AsRock P4i65G Mobo with AGP and a 3GHz PIV (HT-disabled). 1 GB stick of 400 RAM and an old IDE Drive - onboard LAN enabled, and USB disabled. It was vey cheap and works great, although it's not exactly low noise or power-saving (3 Scope boards + ATI 9600XT graphics...)
I used to use a celeron tutatalin 1200nhz which was passively cooled with a zalman flower heatsink. very low power useage, it could be easilly underclocked to about 1000mhz and a lower voltage, since it would overclock to 1500 easy without any voltage increase.
I still have it and an adapter that lets it work in non tuatalin motherboards.
@neutron,
what Mobo did/do you use? What chipset would you recommend for that? I think I will check some old celerons - I remember me also having one celeron 500 which was supposed to get overclocked to 850mhz, in my case it got to 766.. but thats another story
they still are very power friendly. I think I will not even have to use a hard disc. It should be possible to let the unit boot over lan from my first pc which has plenty of disc space free. If it used very little energy I could try to run it with an external passive power supply, but I´m not sure about that yet...
i had that celeron in a TUSL2 and later i put it with the adapter into the original shuttle SFF pc (which died due to VIA chipset crappiness) but the CPU is fine.
you can have it if you want. just pay shipping. the heat spreader has been lapped. (machine lapped, not sandpapered!)
@neutron, your offer is too kind
- I will probaby have to buy one computer by its own, damn, I wish somebody could do this for me, since otherwise I had to buy every part separate and ship it to italy - the shipping costs from germany to italy are mostle immense...So I think I will grab a complete pc, then I will only have to change the psu and the processor urgghhhh...I hate these computer buying things, although I´m not untalanted with it...
