On the DP35DP these are also a problem, but thankfully I won't use the E-SATA connector, or the 5th SATA vertical connection.
The capacitors on a full length card do not seem to be a consideration when this design was made. Luckily with GaryB's 6 inch fingers and a little knowledge of installing the connectors prior to the cards installing, I will still be able to use 4 of the 6, which barely allows the use of this motherbaoard.
On the other hand, the DFI P35 mobo uses the excellent and appropriately placed horizontal SATA connectors. They are definately thinking of gamers w/ big cards. Gamers marketing shares have seemed to benfit us indirectly.
This mobo had better last as we are seeing the support for full length cards and 3 PCI slots diminishing before our eyes.
I will be able to use my pre configured HDD content approach, using 3 x 150GB Raptors. Which are also the last of a dying breed. Large capacity drives w/ multiple platters are taking market share. I have a total of 5 of these w/ 2 in reserve, as I think SSD's will replace these in years to come.
I have prepared for these days by purchasing hardware in advance. Klang's go for dirt cheap, and I fear my greed for more sample based content and storage must take priority. In this way I can use Scope cards until the death of 32 bit PCI's are upon us. I dread the day of a one full length card, mixer based project, but chance favors the prepared mind.
I suppose a PCI riser card could house 3 x Full length cards, but that means a Dremel Rotary tool would have to make 3 cutouts on the ATX case, and I have no idea if these angled extenders are a viable solution.
Astro has seemed to get working results w/ his. But my idea will be drawing much more power from 1 slot to achieve the desired results.
Keep in mind that those of you wishing to do live gigs and use ATX Rackmount cases. 17 - 20.1 inches of depth are good choices. 3 x Full Length cards will cause you to have an external DVD / CD via USB 2.0 if you are using a SATA RAID cage to optimise content housing, tempurature, and noise levels.
This will be the last Intel mobo that can use Scope cards as described. Sad but true.
