I've just bought me a Pulsar 2 card and it got me a little puzzled. It work's great in the Pulsar Environment, but I can't get it to work properly with other software. All software that support (I have not tried Cubase) ASIO, like Orion Pro and Unity DS-1 give me a Scope ASIO option (is this right) but when I try to use this there's no sound. The DS-1 says I'm not running any ASIO ports in the current window project when I try to configure the ASIO settings. I've experimented with different settings in the WinStartP2 file, but nothing I do seems to make any
difference. When I try to run the software with directX drivers I've got a latency of +300 ms before thing sounds right witch make the card useless for live stuff. Any help would be appreciated.
Configurating the Pulsar 2 (by Dr.Strangelove)
Guest
Guest
Guest
Guest
Subject: ASIO Scope Driver is correct.
Remember, EVERY new Creamware product is based on SCOPE technology. They use a unified-driver-architecture probably not unlike nVIDIA uses with all their TNT/TNT2/Geforce cards, one driver for all cards
1. So, load ASIO2 modules into your Pulsar Project.
2. Use the Scope ASIO driver in your programs.
3. Be sure to CONNECT WIRES from the ASIO2 to a mixer, or directly to an output that is connected to your speakers, so you can hear them. Simply having ASIO2 modules loaded in Pulsar won't do anything, you have the power of routing them anywhere! Use it wisely
