extended until January 5th
A reminder:
- if you bought on sonic core website, do not forget to register on spacef-devices.com and fill-in the "User Area Activation" Form. I can make you an access to the user area much more easily and quickly. nb: you do not need to fill the "key request" form, because you should already have activation keys....
SpaceF Winter Special is already active on Sonic Core' Website
--- FP Mixers+FAT Inserts @ 89€ instead of 129 (or 139 later)
--- you get the MB4-16-G for free....., and more nice inserts and modulators now and in the future.
Also, I have set-up an alert system allowing users to subscribe to alerts about new posts in various sections of the website....I think this is more useful to be informed of uploads in the user area, new versions, add-ons etc....
You find this in the user menu near your profile...
ADDED 29.12.07
What is coming (FP/Valve mixers)?
- gain sat: modulate gain like filters. Great for gating or for synching several volumes relatively to each other with one modulator (fader or constant val mmodulator)
- dualizer: transform stereo channels into 2 mono channels..
- more modulators (delayed because under test in "MultiSynth")
- more modulation inputs (and *may be* more modulation sources on mono channels....)
---> make sure to subscribe to the "alerts" to be informed as soon as they are released.
Secret tip: as some of you may know, BlackBox filters are all mono-to-stereo effects: 1 input, and sound on the 2 outputs: so it can be used in FP/Valve stereo channels with modulation (just connect modulation source on the right channel: this will work only if the modulated filter is first in the effect chain). Of course, the audio source is mono (connected on left input), but after the satellite filter, you can add stereo effects (a stereo delay, an S-Filter). This tip is useful in case of emergency when you need to add some modulated stuff to a mono signal (the tape channels are fine for that, then you send to the Fx Bus or to an aux, or record as audio).
- MB4 family: there will be discounts too
-- discount 1 for those who bought the mixers and fat @ full price.
-- discount 2 for those who bought a winter special
Amount of discounts not decided yet but should be substantial (or interesting anyway).
- MultiSynth (4 parts synths, multi-timbral 4 parts or layered, splitable (4 parts + 2 parts for special features, pure analog phaser, lots of options)
--- discount for those who bought the mixers and fat @ full price.
--- will be released before the mixers updates, because a few modules meant
for the mixers are currently tested and improved in the synth.
All this is valid only if i don't die of exhaustion first....
But right now, I am in hollydays and gonna watch some stupid blockbuster movie. yeepee
take care
Mehdi
