XTC problem with Cubase SE3
When I installed the XTC Plugins and started cubase the first time the plugins were loaded appearing several error nessages but the XTC Plugins are listed in the plugin folder. If I try to load a plugin the following message appears
"Can´t find DSP file VST PlugIn VxD - Please check installation."
Any ideas what´s wrong? I´m running windows vista on a new DELL PC with dual core.
				chrisfischer
Yes i´m still using vista and still the same problem. I´m running my sfp software with xp compatibility mode and most of my software is working. I´ve for hours read the manuals and copied the plugins into other folders but didn´t get any positive results. The xtc plugins are available in cubase and it seems allright but I can´t start them.
Good statement, why using xtc and slow down the soundcard. I just like to check it out.
Ralf Bach from Soniccore says that the new platform will be out soon and I hope it will work then.
				chrisfischer
Re: XTC problem with Cubase SE3
Problem solved!   I´ve quitted Vista and run XP on my PC and everything is fine. I´ve waited for the Vista Update nearly a year.
Have fun.
  I´ve quitted Vista and run XP on my PC and everything is fine. I´ve waited for the Vista Update nearly a year.Have fun.
