FP 106C - updated to V 1.6
Planet Z Announcements
spacef
Post by spacef »
July 2009
FP106C updated to v 1.6
http://www.spacef-devices.com/index.php ... n-1.6.html
April 2009
FP106C updated to v 1.5
June 2008
FP 106 - C
A great update to FP106B Mixer for Scope,
- Extended modulation capabilities (8 inputs, 4 with reverse by default = 12)
- Independant modulation for mono channels pre-filters and inserts (independant mod.source, mod.gain, f.offset)
- Superb redesigned mod to CC: now sends to surface parameters in addition to inserts. Longer Lag time, 2 type of CC destination 1// "CC4" (1 source to 4 dest CC) -- 2// 4 independant sources to 4 destination, linkable to group 1 lagged output.
- .. and more
Available now in FP Mixers area
The FP 104 and 106 Mixers are available
V 1.1 - available
less than 3.5 dsp when fully activated.
More info: http://www.spacef-devices.com
Quick Description (extracts from the website).
Full midi control / recall through project and presets.
4 or 6 Mono Channels with:
- Mute (post input/pre-3inserts)
- Solo ( (post input/pre-3inserts - bypasses the mute)
- Linkable Levels (odd/even pairs)
- 1 input/pre-filter mono insert slot
- 1 modulated Multifilter 12dB/resonant
- 4 mono inserts
- Mix On/Off (send or not to main master out)
- Pan
- 1 Bus FX Send with Pre/Post pan/level position
- 3 Aux Sends with Pre/Post pan/level position
- Level (-inf + 12dB, 69 images rotary, same curve as a fader, 0dB at 3/4 approx, leds change at -inf, -12, and 0dB)
- Vu meter (42 leds, colored leds for –12 / -6 / -3 / -1 dB)
- Vu meter margin (infinite peak hold)
- Gain indicator (typable)
- Typable text area (8 characters)
- Choice of text label colour and channel light.
12 Stereo Channels (10 normal+2 tape with bus/aux sends)
10 “normal” stereo channels with
- Mute (pre)
- Solo (pre)
- 1 input/pre-filter stereo insert
- 1 stereo modulated Multifilter 12dB
- 3 stereo inserts
- Level (-inf + 12dB, 69 images rotary, same curve as a fader)
- Stereo channels 9 and 10 provide a button to activate feedback.
+ 2 stereo tape channels with bus/aux sends:
1 stereo Fx Bus channel with
- External input with gain, mixable with channels Bus Sends
- Mute
- 3 stereo inserts
- Signal Wet and Dry controls, where the dry can be selected from several stage of the channel.
Available dry sources: input, pre-insert, filter output, insert 1, insert 2. The insert 3 signal is always on the Wet channel.
- 3 Aux Sends with Pre/Post level position
- Choice of text label colour and channel backgrounds.
- Feedback button to allow feedback loops.
Read more on the website about the:
** 3 Aux Returns
** Rec Channel Output
** Remote Panels and Fx Bus Vu
** Master Section
** Other
bill3107
Post by bill3107 »
Great ! I think i have found the mixer i was looking for when rooting stereo buses from samplitude ... Seems very handy !
Just one question though : for bigger projects how is it possible to cascade several mixers ? I mean, as i used to mix within my big scope mixer, what would be your advice ? This new mixer could be dedicated to the stereo buses from samplitude (here sampler + stylus RMX + vsti) and another one would focus on mono channels on which i will apply scope effects ... I have never tried to put several mixers in one project so ... any workaround against side effects ? thanks !
Jo
PS : Man i need a third screen ! :D and a Beringher BCF2000 too :wink: !
spacef
Post by spacef »
The version that are currently released allows chaining of Aux (by sending the aux out of a mixer to the other mixer aux returns inputs, like with any other mixer) and opening of other mixers' panels with the "p" buttons.
Then you can also plug the master out of one of the mixer to the tape in channels of the other mixer (or to any stereo input).
- If people are interested in chaining mixer, I can easily upload a version with the aux returns input at the top (to plug to aux send at the bottom) or at the right.... Same with FB5/V82 (but not as a demo).
- I didn't include the solo linkers yet (allows linking the solo status and kill solo features)....
-the number of mixers that can be chained depends only on one's ability to bear the augmentation of cable connections in the project window.
spacef
Post by spacef »
by the way.
- demos were re-uploaded yesterday (the sound was scrambled in the first demos two days ago). You have the latest demo if the zip includes the colors and lights presets.
- normal price of the mixers should be 67. not sure yet when i change the current price.
- coupons for spacef users is now 15% (instead of...14 :-)
- another thing that can be customized is the number of LCD colors and light channels. I will wait for users to see with them if necessary and which LCD to keep/remove. The LCD/graph/hi res potis do not really take ressources, but they make the device a little bit longer to load (mainly because of the 69 image potis. The lights/colors LCD are equivalent to 5 or 6 of those, ie, not much.
Coolness.
Tau
Post by Tau »
Great! I've been waiting for these for some time! Now I can retire my beloved mc2, as 10 stereo channels seems to be the magic number for my productions!
Congratulations, Mehdi! great work, as usual :)
T
I hate to be a ball buster Mehdi, but could you post a pic when you get a chance of how to use either of these connected to the V82.
I'm thinking that would be a great combo.
spacef
Post by spacef »
VP2?
i guess it is one of your midi box (i thought it was "fp8") but can't remember a link or the manufacturer... Please refresh my memory so i can have a look...
Your V82,...............Sorry.
spacef
Post by spacef »
for example, the FP104 and the v82 give 12 mono, 14 stereo channels (10+2 on fp104, 2 on v82) . with FP106 its 14 mono/14 stereo
here is an example with 32 asio channels. V82 connected to FP104 tape in. then dragged to the left for better cable graphics. the "panel remote" of both mixers are connected together.
The aux effects are on the fp104 here. If someone wants to chain 3 mixers, then the 3rd mixer's output go to FP104 tape2, and the aux out of the 3rd mixer simply go to the aux retur inputs of the V82.
Please note that I should release variations that allow cleaner projects....
Shroomz~>
Post by Shroomz~> »
Very cool Mehdi.
Keep up the great work!!
A God Amongst Men.
if he only was a woman...
Music Manic
Post by Music Manic »
hubird wrote:if he only was a woman...
Then he'd be a Goddess!!
aarrghh! :-D
nightscope
Post by nightscope »
scope4live wrote:A God Amongst Men.
Indeed, and a veritable Colossus Of The Animated GIF.
Very helpful graphic, Mehdi. :)
I shall endevour to be tidier with me routing.
ns
spacef
Post by spacef »
i don't think i am any god or godess, or if i was one, i would be one with no ftp server this week end (and the 7th day, he had to rest.... because the ftp was not working...)
Uploaded in user area:
- FP Mixers with aux returns at the top.
- tutorial about chaining mixers: this page
Awesome, I await the next in the series.
bill3107
Post by bill3107 »
thanks again for your tutorials ! I have definitly found my mixer set up ! And the keymaster (Ralf) is back so i will test those monsters next week-end ! :wink:
spacef
Post by spacef »
FP104/106 - V 1.1 available in user area.
V 1.1 is an essential update for FP104 (insert 2 fix).
- FP104/106 Midi assignments for pans were not recalled in presets, only project. Now fixed, midi controller presets can now be used again with pan.
- One single download including version with aux returns on top.
- changed demos too ( demo v1.1).
Of course, previous preset/midi controller presets are fully compatible with the new version.
