I used the modular to build some waveshaper functions , the waveshaper sounds ok if the input was a modular OSC. But if i connected external audio ( from other scope synths ) some shaper do not the right job.
Because of the following behavior:
Multi OCS out -> mix2 In 1
Multi OCS out -> Inverter -> mix2 In 2
Mix 2 Out …. No sound .. so far so good
Audio in 1 -> mix2 In 1
Audio in 1 -> Inverter -> mix2 In 2
In scope rounting window, any synth connected to modular in
Mix2 Out …. Hear some sound artifacts, .. why ? ..if I mix a signal and the inverted signal the outbut should 0.... or not ?
Multi OCS out -> add2 In 1
Multi OCS out -> Inverter -> add2 In 2
Add2 Out -> Gain 6db …. No sound .. ok
For Mix2 all controller set to max.
Is this ok ?
lg widy
