problems with using a version 1 card with a version2 card?
- the19thbear
HI... do you know of any problems using a version 1 card together with a version 2 card?
I get the latency of a version 1 card, even though i use a version 2 card in the same pc, right?
any xtc mode or normal sfp mode problems?
thanks!
thanks!
- the19thbear
thanks
thanks!
have you experinced any problems at all?? xtc/sfp problems?
thanks!
thanks!
Re: thanks
I'm on mac, no XTC support on OS9...the19thbear wrote:thanks!
thanks!
I don't have a type 1 card, but the subject is often discussed on a site called planetZ
- the19thbear
- garyb
- Moderator
it'd probably be just fine. currently, my main machine has type2 15dsp and pulsar1 and pulsar1 srb cards. i have no troubles with it, and since i use it mainly for recording and mixing, pci traffic has not been an issue. fepending on what plugins you actually use, you may or may never have problems. the type1 does not load big projects as well as the type2, although the difference is not huge, the newer cards just work a little better, and the type1 won't load massive numbers of reverbs or delays like the type2, but it will load enough traffic for a normal mix. for some heavy-duty synths like solaris, you'll want the later card's performance, but a mix of the two WILL work.
if given a choice, take the newer card. if it's really a matter of money, the old card will definitely help and will provide lot's of extra dsps, which is always nice...
- garyb
- Moderator
- the19thbear
thanks
thank you thank you... so all is well!
I am awaiting my 15dsp card!!! please mailman, hurry up!
