A Bit of Hardware Advice Please
mausmuso
Post by mausmuso »
Hi Guys,
My old P4 2.4G Gigabyte Mobo with 1G RAM is just not cutting it anymore, so its time to upgrade.
I have a SCOPE Pro and a Pulsar 2 card in my current machine.
I work mainly with both Cubase 4, Reason and Samplitude 9 (Mainly for mastering)
- Can anyone recommend a Mobo?
- Is there any Mobo's to take wide berth from?
- Should I go for Quad Core? Is SCOPE Ok with dual core CPUs?
- What would be the minimum recommended RAM? I am thinking maybe 4GB at this stage.
- In my last Tower case I had to cut a section away to fit the SCOPE card in. Is there cases that will take it without modification?
- Also I am looking to invest in a second SCOPE Pro. Is there cases that will do the job?
- I have a DVD Burner and 3 IDE Drives currently (1 with windows and apps, 1 with projects and 1 with samples). I note most modern boards dont cater for that many IDE devices. Can you suggest work arounds?
Sorry for all the questions but who better to ask than SCOPE Pros,
regards
mausmuso
Intel DP965LT / E6750 for studio or live .
2GB's of DDRII PC2 6400
I used this since it's release.
Zero crashes, and Scope reverbs can be used w/ several instances.
bool
Post by bool »
Gigabyte's boards from these series also look nice:
http://www.gigabyte.com.tw/Products/Mot ... uctID=2544
GA-P35C-DS3R is also interesting.
on some variants (like this particular one) the green connector is a major pita.
most variants don't have firewire, so a pcie card would be required if needed.
rev.1 has classic mouse/keyb/lpt/com ports.
they have 1 (one) IDE ch., so you may want to invest in an internal sata burner etc.
they say it runs cooler, from inspection of a sample (got one for my next build, it will take some time though) I can say the heatsinks are placed reasonably well. You also get a eSata connector with POWER plug - you can backup your box easily if you bring along an ORDINARY sata HD (yes, I'm cheap).
from internet readings it works with cheap ram (patriot etc.) as well if need be (if you need to stuff it with 8gigs etc).
mausmuso
Post by mausmuso »
Hi Jimmy,
I assume 'this Dawg will hunt'??
What CPU do you use?
Stardust:
I dont know this test. Is it a Memory Voltage Test?
Can you give me a link on this one?
Thanks also to Bool. I have used Gigabyte for many years now without any great trouble and yes that board does look the goods.
regards,
mausmuso
The E6700, a slower version of the E6750.
It all depends how much ASIO stuff you want to use. The E6750, or the faster E6850 ( 275 USD ), are plenty fast.
Quad cores are a little slower, and Sonar seems to take advantage of that better than Cubase does.
Research the threads here.........http://www.dawbench.com/
That way you can make a better decision as everybody here benchmarks their DAW's in the same quest that we desire.
