Creamware - EDS16i
				Guest
				Guest
the bassdrums can be manipulated widely and you can get nice clicks or deep 808like kicks. and it´s nice because you have two bd´s. the snares have a wide range, if you like plastic plocks but don´t sound very brilliant or natural. what is really a problem is the very much limited and special sounding hihat-section. you can use it once or twice, but than the sound is too obvious. also in general there is no lfo for modulation. in order not to be so fixed there should be the possibility of adding short samples or changing the oscillator-waves. also i think it eats up a little too much dsp-power. what seems to be interesting is the question if creamware will ever work on updates for their devices, because it seems that they don´t do that like other companys who only work on synth/drum-devices. probably they have to work on different things, but so it gets 1 star less.<br>
						<a name="planetz-file"></a><a href="http://www.creamware.de/en/Products/Plu ... S16i"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Price ($USD): 60<BR> <a name="planetz-tag"></a>Type: Synth<BR> _____________________________________<BR><BR> No samples! Real virtual analog percussion at its best! 16 different instruments to generate some heat. Up to seven parameters per instrument give you full control over your sounds. Stereo out plus 16 individual outputs. Comes complete with 20 drumsets (Dance, Electro, Classic, Hiphop...).
<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.creamware.de/en/Products/Plu ... ltpics.asp" BORDER="0">
