re-insalling cards. A bit lost without the manual!
raztalove
Post by raztalove »
I am rebuilding my computer from scratch. My new mobo is the dp965lt. I am confident in installing everything else properly except my creamware cards.
They are: Pulsar 1, Powersampler
I am taking gary b's advice from another post which is:
"like i said, if it were me, and i wanted a useful machine to make and record music, i'd dedicate the computer to that task and reinstall windows from scratch. that means repartition, FULL(not quick) format, and then reinstall the os. then install motherboard drivers. then install video drivers. then turn off the xp eye candy(control panel/system/advanced/performance/settings/adjust for best performance)then install the scope card and it's driver. then check for shared irqs(in system information/hardware resources/conflicts-sharing) fixing if nessessary, then install your software, then install scope. keep it off the internet and it will work properly. "
When searching through the .pdf manul, I cant find any info on how to install the cards, espcially since I want to maker the powersampler card the priamary card for latency. I know that it has something to do with changing the cset.ini file, but isnt this info in an online manual anywhere? I keep telling myself Its right under my nose on the creamware site and I just cant find it.
Is there a manual online that describes the hardware installation procedure of the scope cards?
RL
just put the power sampler card in first and make it the card closest to the video card. restart the pc and install the driver. shut down and install the pulsar. restart and install the driver. done.
raztalove
Post by raztalove »
you rock. Thanks.
RL
