midi freezing
JyGius
midi freezing
Post by JyGius »
Hi all!
When I use cubase to control external synths my system freezes.
I connected my usb keyboard to the physical midi in of my pulsar 2,
and midi out to the external device.
Sequencer Source and Pulsar Source are mixed in a Midi Merger.
If I make midi track in cubase at the beginning I control my external
synth with no problem... but a few minutes later my system freezes.
Is the my midi connection the problem?
I have no irq conflicts.
Many thanks.
JyGius
Post by JyGius »
I will check with the midi monitor .
what are the strings that correspond to this problem?
Thanks.
next to nothing
Post by next to nothing »
do you have midi cables into your creamware card and USB cable to your computer?
JyGius
Post by JyGius »
piddi wrote:do you have midi cables into your creamware card and USB cable to your computer?
Yes. Usb is just for power source.
I could use my keyboad with VSTs without the physical
midi in of my pulsar.
next to nothing
probably a loop, try unplugging either one. if you absolutletly need to use USB, unplug scopes midi, use usb as your midi in to the sequencer, and the midi tracks midi out to Creamware Midi.
Now ,in the routing window of Scope, the midi from your sequencer will be sendt to your Scope MIDI Source. route that one into whatever you want to control.
good luck
JyGius
no freeze anymore (until now)
Post by JyGius »
Many Thanks for your promply and useful replies!
I filtered active sensing using Midi Filter and no freeze anymore!
I will post my brand new project in the Project section.
Thanks!
JyGius
Re: no freeze anymore (until now)
Post by JyGius »
JyGius wrote:Many Thanks for your promply and useful replies!
Thanks!
Errata Corrige!
No no! Once in a while my scope system... continues to freeze... So I can't use
the midi in of my pulsar 2.
You need to filter active sensing externally (between the controller/synth and the Scope hardware input) or disable it entirely in the synth/controller (often not possible).
