Hi all,
My nuendo/pulsar setup is running fabulous thanks to all your advices!
Just a strange problem has occurred...
I have a vocal track with autotune, das sl strip, das mc2 comp on the inserts. (What good plugs. fantastic sound!)
I do the mix, everything fine, save the project, do an audiomixdown.
When reopening the project, the vocal track is down in the mix by 5 db.
Just open the tracksettings (e) and  the volume gets back to the saved volume...
Problem with nuendo 3.2? not everything is saved into the project file?
grouptracks with XTC plugs doesn't suffer.
I have also a lot of pci-overflows when opening the project or when changing settings in the device setup. After the retry, I have the volume drop too.. Look like nuendo hasn't send all the information to the scope.
I took a while to figure out what was happening. I thought I was going mad...
Greetz,
Bart
