RETRO
powerhippo
RETRO
Post by powerhippo »
Hi Guru's
I've been running a LunaII+Powersampler for over a 5 years now :-)
>>>>>>LORD THANK YOU SO MUCH FOR THAT<<<<<<<<<<<<<<<<<<<<<<
and need to replace my audio machine since it's very RETRO today.
P42.55 ,PE4PE,WinXp.........!
Here's my new setup(didn't spend overmuch money for it)!
INTEL CORE 2 DUO E6750 - 2.66 GHZ 1333 MHZ 4MB LGA775 BOX
2048 mb ddr2-667
nVidia Geforce 8600GT PCIe
ASUS P5B
2XSATAII 250gbHDD
LunaII+Powersampler
A16ultra
Does anybody from you GURU'S uses (but VERY Stable) this Setup?
Optimization needed???
I heard that similar setup have guys from www.hamburg-audio.de
Thanks in advance! :)
The E series are great w/ Scope VST combo DAW's.
I use the E6700 on a 965 chipset w/ 2 GB's of DDRII low latency ( CL3 ) RAM, and several Raptors.
It works well with samplers and the endless streaming apps. Live is a dream using Bidule as a shell for various GVI / K2 VSTi's.
Nestor
Post by Nestor »
Hello there new friend! :) Well, I think your choice is good overal, good MOBO too. But don’t expect to be everything trouble free, it is never like this. You have to be ready to fix some minor issues that always arise when we want to configure it for complex tasks.
How will you be using the system for, exactly? How do you work with your DAW in a daily basis?
I guess what's important is the way ASIO and Midi will be working in his setup.
Can't think of a solution without sequencer.
Don't have a clue pwrhppo, sorry :-)
powerhippo
Thanks for speedy response Guys! :)
Well,my choice was this setup because it's not too expensive (cca.700euro)
and I think it will serves my turn.(many Creamware users in Germany have it)
Don't know how much WinXP optimization is needed for this setup? :-?
@nestor:
I guess it will be around 6-10 hours daily use! Don't use toomany CW plugs in the project only STS4000.Have quite enough external gear.
For the last 5 years didn't have any issues or troubles with my old RETRO setup,
maybe on the beginning (from Win98 to WinXP) it was pair issues but long time ago corrected.
Greeting :wink:
not too much optimization. the most impotant one is to turn off the xp eyecandy in control panel/system/advanced/performance settings("adjust for best performance).
remember, most of your external gear that's been made in the last 10years, and many older pieces, runs on a dsp chip. don't be afraid to use whatcha got.....
powerhippo
garyb wrote:not too much optimization. the most impotant one is to turn off the xp eyecandy in control panel/system/advanced/performance settings("adjust for best performance).
Ok, thanks :)
ScofieldKid
Post by ScofieldKid »
I always lose track of this link, but it has lots of stuff for optimization.
Check it out!
http://www.musicxp.net/tuning_tips.php
powerhippo
Hi guru's, I'm back!
Seems that I have some Asus P5B issues(PIO,DMA)
The first SATA HDD C: (MAXTOR250gb) is very,very sloooow.(transfer rate 4,9MB/s)
The second one SATA HDD(SEAGATE500gb) working normally (transfer rate 58MB/s)
When I transfer data from MAXTOR to SEAGATE it goes very fast but from
SEAGATE to MAXTOR goes to sloooooooow.
Scope and Nuendo seems to work slugged relay when song is from MAXTOR but ok???
I did following:
1. Updated windows MB drivers.
2. Changed BIOS settings regarding SATA.
3. Flashed BIOS with latest.
4. Unplugging IDE devices
5. Changing SATA cables,jumpers
6. Update ATA controller
7. Update 965 Chipset
Nothing helped, Maxtor is still to slow.
Can't switch off PIO mode in P5B and can't force Windows to
transfer in DMA mode,although in ATA controller shows DMA.
Current Transfer Mode should be UDMA-5.
I attempt to force WINXP to redetect capabilities of all device and to force
win to use DMA:
Deleting MasterIdDataChecksum and SlaveIdDataChecksum values!
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
{4D36E96A-E325-11CE-BFC1-08002BE10318}
This was one of my friends suggestion!!!
But after reboot this values are still there and same thing occur!
Didn't work!
How can I switch off this PIO mode and use only DMA???
Can someone from You GURU's help me,please, I'm so confused!!!!!!
bluesphere
Post by bluesphere »
powerhippo wrote:Hi guru's, I'm back!
I've the same problem with an ASUS P5K and HD Hitachi 160gb SATAII !!!!!
Can anyone help US????????? :o :o :o :o :o
ASUS P5K, Intel Core QUAD 6.600, 2 Giga ram,
2X Pulsar SRB, 1X Pulsar I, 1X Pulsar II, TERRATEC 24FW, NUENDO 3.2, Reason 4.0
powerhippo
If anyone have ANY potential solution of this issues,please participate :roll:
As I can see on the net, there are lot of Asus P5Bxxx users that have very similar problem with SATA hdd's!
I think that AndreD was the first one who assemble AudioPC with P5Bxx and
it was very successfully built.!!!! :)
Perhaps He'll help us, or someone I hope :)
:cry: :cry: :cry:
what bios settings for your sata drives did you use? can't you enable dma in the device manager?
powerhippo
garyb wrote:what bios settings for your sata drives did you use? can't you enable dma in the device manager?
Hmmm, well that is a problem we have, everything seems to be correct but actually it is not!
In Device Manager it shows DMA enabled, and in Bios you can't switch off
PIO mode(you can choose auto,0,1,2,3,4,5, but not DISABLE)
See my post upon :roll:
My presumption is that WinXP choose by itself PIO mode for first HDD altought
shows DMA in Device manager(on ATA controller).
Maybe mistake was using Standard IDE mode instead AHCI or RAID, I dont know! :-?
yeah, i think you should have used AHCI....
powerhippo
Hi Guru's!
The problem is arranged :)
After hours of agony, I just reconnect MAXTOR HDD from SATA port 1 to SATA port 3 and everything works splendidly :D .
Seems that >>>>the biggest problems = always simple solution :)
powerhippo
stardust wrote::) problems are solved if the solution can be repeated. It seems to me this one is not repeatable. ( Is it ? )Maybe your settings are different for port 1 and 3 ?
Hell knows :-? I'm not touching anything, just do some Acronis backup
and go to make a music! :wink:
:) very happy
arela
Post by arela »
I need a upgrade too, do you sell your 2,55 :-?
Still on 2,4 :D - but at least i'm thinkng of upgrading :o
powerhippo
arela wrote:I need a upgrade too, do you sell your 2,55 :-?
Sorry,already sold :D
arela
Post by arela »
oooh so unlucky :-)
to upgrade or not to upgrade, thats the q
by the way, is your new pc splendid?
powerhippo
arela wrote:oooh so unlucky :-)
Everything works splendid :) at least so far!
Really big,big difference from P4-2,55gHz.
Many plugins are in the game now almost without limitation :D (joke) ,URS,,Waves,Oxford etc,etc, I'm so happy now :)
Dont have intention to change anything for at least 5 next years :D !!!!!!!!
