Creamware A16
chrismathewsjr
Creamware A16
Post by chrismathewsjr »
Good afternoon guys,
I've been offered a used Creamware A16 unit but I'm having trouble finding out all of what it does.
Firstly, I'm not entirely sure what the Z-link connectors are. Are those the same as Firewire?
What I'm actually looking for is a cost effective way to begin recording to my PC. I have tons of analog preamps that I've been running to a tape machine for years.
Thanks for your help,
Chris Jr.
unfortunately z-link is not firewire although it uses the same cable. a used luna card would be veryinexpensive and would be very high end when combined with the a16, one of the best ad/das under $1500...
chrismathewsjr
Ah, so it shares teh 1394 standard connector.
I would need, then, to use an interface PCI card?
What are my options for that, which would work with the A16, then?
any of the scope cards or any card with adat i/o.
the19thbear
ok
Post by the19thbear »
get a luna/powersampler card, they are way cheap, ( you can buy their bigger borthers if you want too.) and very good, they have onboard dsp's (luna/powersampler have 3 dsps'). i bought mine for 150 us dollars.
go to www.soniccore.com(formerly known as creamware) here you can find the bigger brothers ( 6 dsps or more)
if you want a small 3 dsp card, i hitnk you ahve to buy it used, as i think they stopped making them, but then again, i'm not sure..
happy hunting! you won't regret you bought a soniccore card! ( formerly know as creamware)
kylie
Rank-o-phile
Post by kylie »
chrismathewsjr wrote:Ah, so it shares teh 1394 standard connector.
yes, running a subset of IEEE1394 with proprietary extensions on top.
to use the Z-Link ports, yes. and that has to be a creamware card.
(it's like motu's audiowire or rme's hdsp link. works only within the family.)
I assume we're talking about the A16 Ultra here, since there is an older model called A16 with ADAT only.
you have several options:
1) a creamware card with z-link connectors (preferably 2 of them to make use of all 16 channels)
- that would be a 3 dsp card like luna2 / powersampler / scope home with adat expansion module
- or a scope project/ professional with the z-link I/O plate
2) a creamware card with adat I/O (you can still use all 16 channels with enough adat ports, but up to 48kHz only)
- that would be, again, a 3 dsp card with adat expansion
- or one of the bigger cards (all plates excluding the z-link plate, since it has just one adat port, but you would use the z-link ports anyway in that special case :) )
3) any other card / interface with adat ports. 48kHz max here, too.
-greetings, markus
