Spdif connection?
majistik
Spdif connection?
Post by majistik »
I have scope luna and i wish to connect an effect proccessor to it via digital ports.
In my luna card i only got 1 spdif output port (that i guess is also an input).
In my effect processor i have diffrent input and output spdif ports.
I have tried to read the manual and understood nothing - so i look at the pictures and there is most likly a cable for this. where can i find such thing or any othe solution.
Thank you.
something like this with 2 proper sp/dif cables will work:
http://www.hosatech.com/hosa/products/GRM-193.html
majistik
wa
Post by majistik »
What? isnt in analog?
i beg your pardon?
majistik
Post by majistik »
I do not really understand all of this routing stuff...
but it looks like an 1\4" analog Adaptor
I need a digital adapter? am i not?
Please explain to me again since i dont good at this
Thank you so much!!
pistoguitar
Post by pistoguitar »
You don't actually need a "digital" adaptor, as one thing is the physical mean by which the signal is conducted (the cable) and another thing is the encoding of that signal. That's why you can connect a midi Keyboard via USB to a PC and still send MIDI signals.
You just need a good RCA cable and the adaptor that Gary showed you.
"Una risata vi seppellirà..."
pistoguitar
pistoguitar wrote: You just need a good RCA cable
I mean, a good coaxial cable with two plugs, or two separate good coaxial cable.
(Yes, the point is buy GOOD cables :D ).
yes, that's the right adaptor. be sure that the cable is a digital cable, however....
majistik
hmm
Post by majistik »
so it will look like this:
Creamware card spdif ---> adapter ----> two cables like (A) one male and one female spdif ----> spdif effect proccessor
(A=) http://www.ramelectronics.net/assets/im ... f01-xx.jpg
what connector does the processor have? if it's rca, then the cable would be like this:
majistik
yes
Post by majistik »
yes sorry! thank you very much i will try this
sure, just make sure it's an s/pdif cable and not an audio cable.
