When you are in XTC mode in Nuendo e.g. and you use many scope effects without overloading the DSPs and with a lattency of 24ms does this affect the audio functionallity? I mean things like project crashing, pops, clicks etc
Any experiences?
						DSP and audio
Just as i thought. Thanks man. I 'll try to keep the balance.stardust wrote:when you use a lot of effects and especially those that need system memory like reverbs and samplers you need PCI bandwidth. At a certain point this might reach the limits and create dropouts.
Also if you use your CPU with native (VST) devices the scanning of the PCI interface needs to be balanced with the other cPU cycles and finally might lead to overload situations.
It is always a question of balance
