I want to be able to have two or more sequences running but at different tempos and full 16 steps.
For two sequences the first thing I tried was a ramp outputing direct to one sequence and to a ramp  division module(misleading name as it actually multiplies) set to 0.5 for the second sequence. With this I get the halving of tempo no problem BUT when the master ramp resets the halved tempo sequence resets. I want the second sequence to continue for it's 16 steps.
This is the same for the poly rythmer. So is there a simple way to do this that I am missing?
						Flexor ramp divisions?
Don't halve the tempo, double it using the same module.  Master ramp should be the longest event.
				irrelevance
