OKTAVIANUS
MCCY
OKTAVIANUS
Post by MCCY »
Oktavianus is another FETTA-Technology EQ, but again with a completely different overall internal design.
More important than the EQ at the bottom of this effect are the above settings, which subtle soundchanges are rather complementary to the main EQ. I found that emphasing in the above section may be well confronted with reducing in the main EQ section.
OKTAVIANUS is quite heavy on dsp. I'm thinking about a reduced version.
EDIT: Added OKTAmed, OKTAmed2 & OKTAmini to the package. Soundwise this makes a difference, but for some cases you won't need the big one.
have fun !
Martin
OKTAVIANUS.zip
(226.91 KiB) Downloaded 669 times
MCCY
Post by MCCY »
P.S. use it on a bass drum & you will get, what it's about 8)
hifiboom
Post by hifiboom »
thanks Martin, I will have a look on it.
