how to connect 3 adats in& 24 asio
Scope project files
HansKadans
Post by HansKadans »
I have recorded 24 tracks on a hd24
How do i make the right project to get these 24 tracks into cubase?
My hardware: scope project and pulsar card in one pc.
hd24 connected with 3 optical cables
cubase sx3
I dont know how to connect 3 adats in a project
I dont know wich mixer to use. ( 24 in en out)
a picture of the project i need to setup would help...
Thanks,
Hans
wayne
Post by wayne »
Use your 3 Scope ADAT Source modules. Connect to ASIO 2 Dest module.
You will need an ASIO 2 Source module in the project so cubase will work - double click on this module to open ASIO settings and increase dest channels to 24.
HansKadans
connections?
3 adat source modules to Asio 2 dest module (ok) :)
How do i connect the Asio 2 source module?
Is it possible to make these connections using the 2448 mixer?
If Yest, how?? :-? :-?
(In real life, I have a mixer with 24 in's and 24 direct out's, but i cannot find that on the virtual 2448 mixer and besides that there is the problem of connecting the 3 adat source modules and the asio2 source (24 ch) to the mixer)
Do you have a picture of the project file I need?
Please help me out, I'm desparate..
Thanks,
Hans
arela
Post by arela »
something like this pic.
This is for recording directly from ADAT, but still monitor the mix.
IYou can also connect ASIO2 Dest to right side of mixer, but then you might need to record to stereofiles (?? not shure about this)
adat project.JPG (74.66 KiB) Viewed 25125 times
ray
Re: how to connect Yamaha Mixer O1v96v2 To scope 15dsp spdif
Post by ray »
Hi
Can AnyOne help Me to connect Yamaha Mixer O1v96v2 to Scope Via SPDIF to record A Digital Vocal.
I've tried The scope Spdif source and destination :Samplerate slave. Nothing
Cheers
