Gary B I Know Your Surfing Out There
My Brotha' From Another Motha',
I have installed many things today, you would be proud. But I have come across trouble w/ the password entry to free up my mouse. Thanks God Scope loads w/o this so I can at least check audio / MIDI connections, and they are fine. The back of the rack has two of my old hardware reverbs back which I need to bring into Scope.
I only need the password to unfreeze and finish my chores.
Below are two shots of the 28U DAW's. I am also hooking up the ancient Giga 2.54 DAW w/ the DP's today as well.
I Am At Your Mercy Cabron,
After 1 hour of trying combinations of numbers, it turned out to be " 000000000 ". Imagine that. Each DAW had a window w/ an annoying caption above my routing window tabs, this is gone now as well.
Aren't you proud.
yes.
When shutting the drawer, since the 1U's are all rather tight, my no # 2 KVM light gets hit, and activates. There was nothing I could do about this, so I put my most needed DAW in the # 2 slot. Now when I close the drawer it automatically shows the GVI / Bidule DAW on the LCD automatically. One less keystroke is a valuable feature, so this stays.
Battleworthily Yours,
