I have almost always sfp crash when try to just load sts-3000 ,didn't have that before with two pulsar II cards and one pulsar pro.
I have that now with three pulsar II cards !
All other things exept for samplers do not crash SFP.
Even if sts2000 loas or sts3000 (sometimes on full projects) when I try to load pool preset samples then immediate crash...
Any hints ???
Dimitrios
sts 3000 crash problems need fix !!
Re: sts 3000 crash problems need fix !!
i have the problem too. Just STS 2000P will load sometimes. Loading STS 3000, 4000, 5000 cause crash of SFP. I am running CW Scope board (v 1.3, 14 dsp) with Scope v4.5 under win2ksp4.
Thanx,
Robert.
Thanx,
Robert.
first I tried to switch ACPI off - no change.
Then I checked my memory timings in BIOS. I set it to lowest possible values - no change.
Then I checked my RAM with Memtest86+ (http://www.memtest.org/). It runned all the night long and report no errors!
Robert.
Robert.
I loaded all *.sts files from HDD. So I think the problem is not loading via ASPI from AKAI-CD.
I posted the problem in a bug-report to SC.
Regards,
Robert
Regards,
Robert
