Strumming 6 string
Kymeia
Strumming 6 string
I've been trying out Mamba with 6 string and it can make some excellent strummed chords but ideally I would like to be able to use the mouse to strum so i have more control - i.e. I set up the pattern in advance and then play using the mouse. Anyone know a midi or Scope plugin that can let me do that (I tried Arpeg but not really)
Six String is a great hybrid model.
I find it is most realistic when I do acoustic and electric finger picking styles, i.e. John McLaughlin, Leo Kotke.
Strumming should also be fairly realistic especially if you know which strings are open, capoed, and basic guitar chord structure. Nothing sounds more cornier than guitar emu played with un natural voicings.
If you have no luck w/ a device, a good alternative is the Oberheim strummer, or if you want to be exotic and add many more tricks including a ribbon controller, the Kurzweil Expressionmate.
I had a friend with limited keyboard skills pull off a rather good Flamenco guitar duet by using this on a decent Kurzweil sample, then playing the real instrument over the top. It sounded very good as the real guitar was the kind.
Good Luck, the Oberheim on ebay goes for about 10 - 35 USD.
LHong
Re: Strumming 6 string
For the MIDI:Kymeia wrote:I've been trying out Mamba with 6 string and it can make some excellent strummed chords but ideally I would like to be able to use the mouse to strum so i have more control - i.e. I set up the pattern in advance and then play using the mouse. Anyone know a midi or Scope plugin that can let me do that (I tried Arpeg but not really)
1> If you have Cakewalk/Sonar, something's called MIDI enhancer tool (3rd party - it allows realtime plugins with MIDI track ) or the StrumKey Cal program (offline process).
2> Other standalone tool is the Jammer-Pro accompaniment MIDI Sequencer (about $125.00) from soundtrek.com. It has the various styles and lets you export to MIDI file.
However, I would do live guitar (record tracks) sometimes as I can
http://www.planetz.com/forums/viewtopic.php?t=22672
Good luck,
LongStudio
LHong
Kymeia
Yeah I can do my own picking but a real strum is more like an arpeggio with a variable time element and direction so I thought an arpeggiator might do it (but it doesn't). Ideally I would like to see a visual representation of the strings and frets and just strum up or down with the mouse - that way I could also choose which strings to leave out and could play dynamically rather than in a pre programmmed way. AFAIK Mamba is pretty much like a software Oberheim Strummer and very nice but it just lacks that manual control to give it a more human factor (I suppose its a bit like needing a breath controller to give horn sounds that human touch)scope4live wrote:Six String is a great hybrid model.
Maybe I need a midi guitar
- Polarity
or you could find a Digitar!!
It was a special MIDI controller made by italian Charlie Lab.
It works very well.
Practically it has six metal bars on which its software put the notes exactly like would be on a real guitar if you were playing a chord:
you use one hand on keyboard to play a chord and with other hand (and a plectrum if you want) plays notes on metal bars (that has velocity too) of the controller you bind to your hip.
it's perfect for strumming or doing arpeggios.
Of course you can send chords from a previously recorded track in sequencer.
Try a search on ebay...
New was about 250 Euro (we are talking of almost 10 years ago), but you can't find one new anymore. Out of production since years....
It works very well.
slammah2012
"Creative" used to have one on the Soundblaster live CardKymeia wrote:Anyone remember the Atari programme called Midi Mouse? - that had a strum mode. That's the sort of thing I'm looking for but for Windows (or ideally a Scope device
It was called Creative Keytar...
Time has No Master.
*NOW* is the Password.
Just *ASK* and *INVITE* every-
thing you are after..........
