The Latency in XTC mode is showing as 26ms in CubaseSX3 and feels very slow when monitoring. Is this the norm for XTC mode or can something be done about it?
Thanks in advance.
						Latency in XTC mode
So you've found out how to keep it from resetting to 25 ms each time you start up Cubase?
Intel Core 2 Quad Q8200 2.33 GHz 3 GB WinXP Home SP3 / Cubase 5 (5.5.0 Build 602) / Creamware Luna (Scope 5.0.2603) / M-Audio Axiom 25 (4.2.0.3v4) / NI Maschine (1.6.0 R6516) / Behringer BCF2000 (V1.2.1.3)/KRK VXT4
http://soundcloud.com/lotuz
				Eric Dahlberg
Posted by Gonzoft:
"7. XTC mode does not remember your ULLI settings unless you do the following:
Add the following entry into your /SFP/App/Bin/Cset.ini under item
[XTC-config]:
intBlkSize=x
whereby x is a values out of 64, 128, 256, 512 or 1024 and translates as follows to the card's latency:
64: latency = 3 ms
128: latency = 4 ms
256: latency = 7 ms
512: latency = 13 ms
1024: latency = 25 ms
A wrong latency will still be displayed in the ULLI Settings of the ASIO Control Panel, but you can ignore this.
[XTC-config]:
intBlkSize=x
64: latency = 3 ms
128: latency = 4 ms
256: latency = 7 ms
				Eric Dahlberg
