What Mother -Processor are better for the Pulsar 2?
- micro.JPG (185.8 KiB) Viewed 2794 times
- mother.JPG (152.1 KiB) Viewed 2794 times
I currently run a E6420 @3.2 GHz and it performs very well. lots of CPU power, stable and easy overclocking, but runs relatively cool with low power consumption.
For A/V workstations I would prefer Intel, AMD makes gread CPUs too, but the Intel chipsets / boards IMO are still much better and mor compatible the the AMD stuff.
:: www.deepcode1.com ::
sounds, vision, interaction
I just bought and set up a Asus P5K deluxe with Intel Core 2 Quad, and 4 gig Corsair Ram. Kicks like it's on steroids...
Only thing is. You need a pcie graphics card wich will overlap PCI slot 1 (if it got the silent cooler rib attached). This leaves you with PCI 2 and 3 for your pulsar boards and a really cramped space. I guess I might experiensing heat issues wich I (you) need to address.
Another issue is if you really need all the features the Deluxe issue gives you (2xgblan, wifi, etc..) I found myself turning of these features beacause of Pulsar stability.. But then againg the bios support 2 bios profiles which makes this board handy with a dual boot XP (one for Scope and one for other other stuff).
Why not Quad? Aaaahhhhhhhhhhhh...174 loaded SSL comp in cubase and only 50%cpu
wokrs fine even with a combination of duende, scope (p1+scope) and UADe (PCI express).Guido wrote:What do you think about this configuration?:
Mother : ASUS P5K Deluxe/WiFi-AP LGA 775 Chipset P35
Processor : INTEL CORE 2 DUO E6750 2.66 MHZ 1333 FSB 4MB
RAM : G. SKILL 2 X 2GB DDR2 800 (PC2 6400) 5-5-5-15
thanks!!!!
Guido
All the best,
Andre
