Hardware cannot be setup properly:
System error: timeowt waiting for acknowledge from dsp 9
Could not gain access to the CreamWare hardware!
Is anybody knows what is it? When i fisically touch the bard in a slot- it helps!
But not for a long time! Please HELP!
it's often just a mechanical problem - lift the card from the slot, press it in carefully with no exaggerated force, check that it perfectly fills the slot.
Usually it's the bottom part of the card's slot metal that doesn't sit properly in the respective opening of the case floor and 'bends' the card. I recently had a displaced card by an Adat connector that was a bit too large.
