Delay Issue
pistoguitar
Delay Issue
Post by pistoguitar »
Hi everyone.
I'm having problems with Scope Delays (both Multitap and LCR s): just couldn't get a delay bigger than a 1/4 note (if set in bpm mode, obviously). If I choose i.e. a 1/2 note it stucks on 1/4.
How may I get out of this strange issue?
I'm on Platform 4.0
"Una risata vi seppellirà..."
wayne
Post by wayne »
Try increasing ulli to 24ms
pistoguitar
That doesn't worked. Thak you very much anyway. Any other suggestion?
P.S. I've re-installed SFP for the STS problem I've talked about in the other post. Now my samplers are working good (I believe though that was my samples hard disk that's going bad) but delays have the same problem still.
What tempo are you using?
hifiboom
Post by hifiboom »
there are two delays:
DELAY S and DELAY LS
Take the LS ( LONG STEREO DELAY)
depending on tempo, 1/2 may not be chosen on standard delay, because max. delay time is too small...
btw all the bpm settings don`t work correctly, unless you use the highest latency setting in ULLI. (at least with my system)
If I use a lower value, they fall out`a`sync.
pistoguitar
I'm using Delay LCR and Multitap delay, with the second highest ULLI settings and various BPM (from say 105 to 130).
Anyway sometimes it works, so I think I must dig deeper in my projects settings to try to figure out what's wrong.
BTW ULLI settings semmed to be a part of my problems with STS samplers (increasing it made disappear all of those annoying cracks and pops).
