Modular Insert
Modular Insert
These are Insert effects that load the modular pannel.
you can put them into mixers, in synths with inset effects and so on...
enjoy!
*** Saving problem fixed
Important note:
if you want it to load with your projects you must save, and reload in the insert spot. it remembers the path so if you dont do it it will just load the empty modular.
enjoy!
Important note:
				- Modular Insert.zip
- (143.21 KiB) Downloaded 597 times
						hell ya many many thanks assaf!
http://www.oceanswift.net
Music
Music
Uh, very cool, it's similar to a DJMicron's device (I've forgot now the name...)
We must re-build an entire modular patch inside this DEV.
I'm looking (since years) for something similar but that allow to load an entire Modular patch (synth or EFX) without the need of rebuilding (or just copy) all from scratch.
Do you think it's possible, Red?
This solution could be a possible workaround to load and use modular synth inside XTC VSTi mode...
						Dear PlZ'ers
This one is a temporary version that still can't be saved as a single device and not parametrized, we are working to make it complete, that will be very soon.
Anyway, you can start experimenting a bit with it, but remember that the loaded modules are not saved yet so don't use it in important projects that have to be saved and reloaded as they are.
Stay tuned!
Stay tuned!
fixed!
you can save modules inside, since the module saving mechanism has changed it is possible scope will promp you to save the patch, it will not work. you must save the patch in the modular window first.
also to refresh the loading path reload the patch after saving it. else the project will open an empty modular.
other than that it is fully functional as an inser effect.
this is NOT an XTC effect.
realy people, let XTC go! your missing the whole point of scope!
peace!
Assaf
peace!
Assaf
Yep, I know. For this reason I use both: XTC in host PC and SFP in slave PC, linked via adat and ethernet midi.ReD_MuZe wrote: this is NOT an XTC effect.
peace!
Assaf
XTC mode is very useful to load all in one easy & fast project, and to use i.e. UAD FX or native FX with Scope.
A VSTi insert for modular loading is only one of my secret dream... non so fundamental but amazing in some situation.
Thanks ReD.
						- FrancisHarmany
