Cracks and pops when recording with adobe audition 2.0
flexxer
Post by flexxer »
in the past i have recorded my cubase projects with adobe audition and there where no problems now i get cracks and pops
i tried reinstalling adobe audition but it didn't help
can someone advice me please.
bassdude
Post by bassdude »
Have you made any changes to the way you setup your cubase projects since the last working project? ie bitdepth, sample rate?
Stuart.
flexxer
Post by flexxer »
No i haven't changed (maybe something changed unintended) it but it could be an idea to reinstall cubase sx 3
Everything will have default settings or is it possible to put cubase sx 3
in default settings just by pushing a button ?
flexxer
Post by flexxer »
i reinstalled cubase but it didn't help has anyone got some other suggestions?
flexxer
Post by flexxer »
which driver is best to use in adobe audition ?
ASIO DIRECT X FULL DUPLEX
ASIO MULTIMEDIA DRIVER
AUDITION WINDOWS SOUND
if audition and cubase are being used at the same time, you should use the multimedia driver(24bit wav in scope).
open the task manger(cntrl/alt/del) and go to the processes tab. find audition and sfp or scope. right click, choose "set priority" and for audition set to "above normal" and for scope set to low. this should allow proper allotment of resources for two heavy applications like audition and cubase.
flexxer
Post by flexxer »
i get less crackles and pops but the are still some cracks and pops left
flexxer
Post by flexxer »
is there an other program is which i can record my cubase projects without pops or cracks?
or is there another way to setup scope for recording?
what graphic card are you using? what are the specs on your machine?
have you done this? go to control panel/system/advanced/performance and check "adjust for the best performance" on the visual effects tab, and then on the advanced tab, set processor scheduling to "backround services".
this should work, depending on how heavy your cubase project is and how many plugins you're using in cubase. personally, i use samplitude or magix music studio(audio studio from the music studio suite is samplitude lite) for mixdown purposes, what you're trying to do should work, but you can always just record to another stereo track in cubase(from cubase to scope and back to cubase, no problem).
fidox
Post by fidox »
why don't you record just with cubase and then edit wav file if needed ?
from scope mixer to Asio destination and
use Asio Scope driver in Cubase ?
i always do like this, no need to record with other appz, so i have more free system resources just for scope and cubase
matej
Recording back into Cubase is definately the easiest workflow.
flexxer
Post by flexxer »
The graphic card i'm using is pci express asus 7300 gs silent
6600e conroe, 2 gb ddr2 800mhz, mb is asus p5w dh deluxe
pulsar 1 and srb 1 and scope 2
3 hard drives 1 for windows 1 for scope and vsti and 1 for samples
i'm using 3.1b drivers to avoid crashes
i recorded back into cubase(with asio dest) without any problems and i'm very
happy.
But just make sure later i'm going to try to record in samplitude
Thanks for all your help people!!!
