Invisible Mod II modules
minipax
Post by minipax »
Hi, when i load up an empty modular patch i get the Exception: "nil reference on left side of '.' as a result of expression "p"
the device then loads, but when i try to add a module i get the exception: "nil reference on left side of '.' as a result of "_restoredPresetList".
and no module is visible anywhere within the project yet i get a DSP hit.
any ideas how to fix this?
Something isn't installed properly?
minipax
Post by minipax »
perhaps...i'll reinstall later and see what happens..
minipax
Post by minipax »
reinstalled scope and no joy.
just tried loading up the analogue drum kit patch. it loads fine and i can use it, but if i try to add a module, scope just bales on me and closes. anyone got a solution out there? because my Modular II ain't too modular :cry:
Did you install over the top, and did u install the modular from the zip or oxe?
minipax
Post by minipax »
I uninstalled and then reinstalled from the zip.
what exactly is the oxe? looking at it in the downloads section, it only seems to be 1Kb??
