my one hard disk starts perform strange. if i want to play any wav file from that hd.. it start clicks ..pops but other hd is ok. is there any way to solve this prob.
clicks
no i didn't. what is busmaster?stardust wrote:did you change your hardware configuration ?
just start deframent... lets see.
hd setup:
P.Master-60gb - C,D,E
P.Slave---80gb - G, H (sonar project)
S.Master- CDRW
S.Slave --120gb - F, I , J (all Loops SFX as wav)-- Problem hd.*no internet is here or antivirus.
defragment has done. strange is that the click has a certain tempo
is there any chance that both cdrw and hd are working as master
and sometimes no jumper sets the device to cable select which means both device would negotiate who's is master and who's not (does not always work).stardust wrote: Sometimes no jumper on disks makes them master on that channel.
If both CDRW and HD are master you will have some trouble anyway.
if you want to be sure about master and slave, jumper the devices properly. if you set them both master or both slave by accident, chances are good that your computer won't boot, sometimes the devices even don't spin up. so your setup does not seem to be totally wrong...
maybe you have room for an additional controller...?! or sata onboard?
-greetings, markus-
where can i find that?stardust wrote: Are there any options like the direct from disc reading options to tweak ?
Are the disk caches or the rpms of the primary and the secondary channels different ?
i'd check malster salve... 1st jumper on cdrw. 3rd jumper on HD. also i change from AUTO Detect hardware to Secondary Master/Salve.
@kylie you're right. they'lll not boot. is that somethng to do with IRQ!
thanks
