Looking for MIDI X-in Switch 01 dsp-file
synthetic
Post by synthetic »
Looking for "MIDI X-in Switch 01" dsp-file. I think it is Vega and OBX plug which wants it, anyone?
did you check for it in the dsp file?
how about on the install disk?
synthetic
Post by synthetic »
I did not find it in my DSP-folder, or what's the "real" name of the file. I mean whats the filename not the DSP-name. I have M3 and Flexor installed, Vega is M3+Flexor, maybe some DSP is missing from my Flexor-installation.
If so, why does not CW-plugs install all its contents when installing, I think I have seen this before...I've also done the "hidden"-file trix...
synthetic
Post by synthetic »
Where can I find this DSP-file. I re-installed Flexor 1 & 1.5, and it only contains 1 dsp-file (ADXFLX). I also have M2 and M3 installed.
Janni
Post by Janni »
When I try to load Cyprox 1 strip I get this problem message:
Can't find DSP file MIDI X-in Switch 02
Strange...
Cheers,
Jan
djmicron
Post by djmicron »
hello,
it should work by copying the file cyproxlb.dsp inside your dsp folder, but it's the same as renaming it to MIDI X-in Switch 02.
I think it's possible that you have more than one scope installation and you have placed the dsp file inside the wrong dsp folder.
Anyway, let me know if it works.
Thank You
Micron
Also,
I believe that CW's OBX-c has Alfonso's Unison 6 device in it's shell. So you would need to download that from the Device threads. Since I don't know how to do the re- direct trick yet. You have to search for it yourself, but it should be at the top I believe. Glad to see you are grooving w/ Scope.
synthetic
Post by synthetic »
scope4live wrote:Also,
Yupp, this "package" with the unison DSP solves the problem. thank you.
