Here are 4 more modules for the modular:
i. Asio embedded (the asio driver with 8 ins 8 out for the modular. Please delete asio modules from project window before loading). It's nice so to leave the modular inputs free for other devices).
ii. Key number to program change. Send program changes easily with your keyboard. Root note is 60.(in combination with module [iv] it can send program changes from mds8... experiment)
iii. Midi outputs embedded. (will only work with pulsar 2 systems -or these with pulsar 2 in the configuration). It provides Midi output 1 and sequencer dest 1 from within modular. Please delete pulsar midi output and sequencer dest 1 from project window before loading the module.
iv. MDS8 to drum map. It transposes the connected midi signals to a drum map way. Use it to drive samplers, drum machines etc. with mds8. (or 2 mds8!)
You will also find here the missing dsp file midi multimerge 16...
Have fun!
						Another 4 modules for the modular... (plus dsp file mmerg 16
- roy thinnes
- Ben Walker
and thanks again!
http://www.oceanswift.net
Music
Music
