where can ifind presets for scope gadgets?
miki
geoffd99
Presets are in files in the Presets folder within your Scope install.
They should load when you load the device. Or gadjets.
Sometimes it says 'Not 50% compatible' or whatever if they are from an older version of the device.
Third party synths should come with a preset list of their own, which are usually put in the Preset folder manually.
You can also load them using the file handling dialog on the device, just navigate - browse - to the right place and look for the device name.
BTW, sometimes the preset name (eg 'bass synth2' or whatever) does not get listed anywhere, not even the control panel down the side.
Does anyone know a way of displaying the preset name, if not shown? I usually write them into a Notepad for reference (ie if you change it, then want to go back to it later).
