Hi guys,
I have been using Scope for quite some time now but there is one thing that I have been wondering and not got an answer yet.
I would like to use a Pitch Correction tool such as the Antares Auto-Ture or TC Intonator but none of them are suitable for the Scope DSPs.
I wonder if anybody knows of a Pitch Correction software that can work within Scope or , if not, what is the next best solution.
I understand that a VST plugin will only work within a VST host software so I guess I would be forced to open something like Cubase and connect it to Scope via ASIO in order to use it . Am I CORRECT ?
Thank you,
Maz
Third-Party Plug-Ins
logic28
arela
logic28
Thanks for your input.bassdude wrote:The sts5000 can do pitch correction. However native software tools like autotune and melodyne are probably more intuitive.
However, since I wish to use the plug-in in real time, using something like Autotune would involve running a VST host application and I think that would add instability in the system in conjunction with Scope.
I am still trying to locate an alternative that will not require a host app. support.
logic28
beerbr
try Bidule (Standalone).. This might help to load VST effects without host application in (almost) real time.
www.plogue.com
www.plogue.com
