(I wiill have my Scope Pro in about 3 weeks so this is for when i get it)
I have always composed my music in a 44.1 KHZ / 16 bit environment ( Cuabse ), I experimented with 96 KHZ / 16bit . When I played with Pro-53 Vst there was a very noticable difference in the output.
It was much more "sprakly" and just plain sounded alot better.
Should I be Composing in a 96KHZ environment?? the only problem is ALL of my samples i use are in 44.1 so when I put them in the 96 environment its like hearing a tape being fast forwarded
 And what is 192 KHZ for ??? Im guessing its to do wiith the Mastering Stage.
 Honestly, Pro-53 sounds pale compared to Pro-12 or zarg's various Prophet models. Unless you're doing some amazing mastering job or high-end DVD work there really isn't much to be gained (in a  mix) by using anything other than 44.1.
