Scop4.5 Installation Problem :/ plz HELP
HF
Post by HF »
for some reason it doesnt let me press next.
i put the serials in the right places, also tried put the serial for scope ver 3 or 4 ,both don't work.
i have the luna 2.
any ideas ? :/
[/img]
can't press next...<br />serials for scop main tools luna soft, luna soft3
can't press next...
Immanuel
Post by Immanuel »
A guy had the same problem, when he bought two cards from me. It was fixed, when he got the allkeys file from Ralf. Email Ralf for an allkeys file, then you are good to go.
HF
Post by HF »
. (double post sry)
HF
Post by HF »
thx i hope it will help,
i try scope 4.5 in hope that it will fix this problem > (asio scope driver dissabled) also in cubase or whatever host i use.
no asio sscope option.
scope asio problem.JPG (29.98 KiB) Viewed 1419 times
Immanuel
Post by Immanuel »
Did you load the asio drivers in Scope before opening Cubase?
Mr Arkadin
Post by Mr Arkadin »
Yes, definitely email Ralf at:
rb(at)creamware.de
with your hardware serial for a new allkeys file before installing.
HF
Post by HF »
already emailed creamware... -.- i guess it will take time till the answer meh...? zzzzzzzz
maybe something is wrong with my scope project? :S
damn i want to work already -.-
Mr Arkadin
One thing i noticed in your project is that you're using a different ASIO module for the Source and Dest - you should make them both ASIO2 (i use the ASIO2 Dest-64 and corresponding Out module - sorry can't remember the name). Doubt it'll make much difference but give it a shot.
