Flexor clicks?
Music Manic
Flexor clicks?
Post by Music Manic »
I've just installed Flexor and find a few patches have clicks in the audio when played.
Is this a DSP problem?
Has anyone experienced the same problem?
you might have quoted the names of the patches... ;)
there may be extreme settings that 'click' as a natural matter of fact
some folks used a ramp generator (not sure about the frequency) for syncing purpose
otherwise you may check your clock sync in the sampling rate window
it's not a normal operation of Flexor, but devices potentially can switch sync source under certain conditions
hifiboom
Post by hifiboom »
if you refer to clicks that are generated by the envelope, I found this following solution....
http://www.planetz.com/forums/viewtopic.php?t=21605
