IUSE SCOPE 4 AND CUBASE SX 3 ITRY TO CONNECT ASYNTH
AND CONTROLL MIDI FROM CUBASE NO CONNECTION
WITH THE MIDI EDITOR ???
SCOPE 4 CUBASE SX MIDI PROBLEM
Herr Voigt
If you have a seq midi source in your scope project and connect it with a synth of your choice, in Cubase should appear scope at your possible midi connections. Take it. The midi channels should match.
If it doesn't help, post your project and a screenshot of your Cubase project under our "projects" column.
And don't forget: texts written in capitals are really hard to read, okay?
Good luck, Thomas
Good luck, Thomas
scope v 4 cubase sx wins xp pro
iconnecet synths in pulsar with the midi merger adifferent one for each synth
and when iaudition in cubase aseperate channell ihear two synnths?
Herr Voigt
Liquid Len
Re: scope v 4 cubase sx wins xp pro
Why do you need a MIDI merger? You would need that if you wanted to feed MIDI from several sources into ONE synth (or wherever you're sending the MIDI to).miki wrote:iconnecet synths in pulsar with the midi merger adifferent one for each synth
