VM-1242 .. no longer available
Shroomz~>
Post by Shroomz~> »
no longer available
fantastic Shroomz, my respect :-)
hifiboom
Post by hifiboom »
wow Shroomz,
what a hell of a mixer... :lol:
simply great, just checked it and it works fine so far...
some feedback from my side:
- solo/mute both mute the channel
- I can route to the group busses but the sound is still routed to the main channel ( so it gets doubled/phaser)
suggestions:
- on/off switches for the EQs to save DSP ressources
(eats up a whole Pulsar Project ( 6xDSP)
Wooow..... :D
Shroomz~>
Post by Shroomz~> »
Hello,
hifiboom wrote: - solo/mute both mute the channel
mmm, that shouldn't happen, I'll look intio it.
The buttons at the bottom beneath the faders (with the green text) switch the channels, aux's & busses on & off the mix.
suggestions:
Yes, it's quite dsp intensive if you don't have a 14/15 dsp board as your primary card, so I might look into that :)
On that subject, you'll need a minimum of 2 x 4dsp cards to run this mixer.
cheers,
Shroomz
Shroomz~>
Post by Shroomz~> »
edit- Just deleting the odd double post bug/behaviour.
voidar
Post by voidar »
Wow :P.. So you mean I can run it on my two pulsars?
wayne
Post by wayne »
Won't load on my Scope Pro :cry:
- cannot add module Mixer Master Gain
Shroomz~>
Post by Shroomz~> »
voidar .... yes you can run it on 2 Pulsars (in theory at least)
Wayne, that version won't run on a single board as it's assigned over 2 boards, but I'm gonna make a version which is assigned to one board which will require a big card & also a version which isn't dsp locked AT ALL. I'll post them today :wink:
Shroomz~>
Post by Shroomz~> »
Added 2 new versions to the first post which have different dsp managment. Try the 'board0' version Wayne !! :cool:
Shroomz~>
Post by Shroomz~> »
The board 0 version has just been updated. For some strange reason it's dsp distribution worked in the sdk but not in Scope. If you downloaded the board 0 version please d/load it again.
Brazda lui Novac
Post by Brazda lui Novac »
Wow, impressive!!! At least the design looks great! I'll check it tonight.
Thanks Shroomz!
Shroomz Your'e Killing Me,
I am far away from my DAWg's but have downloaded this to my wireless HDD. If it just sounds as good as it looks, I will be rejoicing. This is great as I have time to play w/ this for 2 weeks b4 my next gig. Awesome !!
Shroomz wrote:
suggestions:
I'd like this as well, both for dsp saving and just to eliminate unnecessary circuitry when it's not needed. Bonus points for doing the hi/lo shelves & mid bands independantly switchable.
basati
Post by basati »
WHAT IS THIS !!!
:o
Thank you very very much
(no writen words can express THAT sound)
Shroomz,..My Brotha' Man Shroomz,
I love the sound and have hardly begun to scratch upon this surface. Do you suggest running Move EQ w/ this, I see it is pictured. I'm still messing this mixer since I got home. I downloaded it in Tahoe just in case the PlanetZ server started acted like Creamwares or something, Oh Sorry.
I found that it freezes my synthesizers polyphony when I zero out the Polyphony on yours. So I suppose I should give your mixer 1 voice of Poly, as that seemed to fix it. Does raising the Poly on the mixer allow more plugs or anything?
This mixer is awesome. Kudo's on the EQ arrangement, as I can do vocals, synths, and about anything you throw @ it, Extremely versatile. This mixer w/ Move EQ is worth buying a Creamware Professional card to run it. I can't believe the balls on the samples I love so much. John Bowen should hear his synths through this FAT BASTARD.
May You Be Molested, By Large Breasted Babes,
wayne
Post by wayne »
Sounds fantastic, very musical. Thanks Shroomz & Sharc!
Brazda lui Novac
How about an on/off switch on the EQ Shroomz? That would save a lot of DSP...
Great work! Thanks!
Brazda lui Novac
Oops, hifiboom already pointed that, sorry...
rodos1979
Post by rodos1979 »
Thank you Shroomz very much for the device! :)
I 've just downloaded it and I am going to try it... I have another request.. :oops: ..Is it possible to release these versions with a GUI that fits into 1024*768? ... Or am I the only one who still works with that resolution? :-?
Mr Arkadin
Post by Mr Arkadin »
i agree with rodos. Even though i have higher resolution than him it's still huge on my display - i can just fit it in if i drag it over a bit, but it's a squeeze with the Live Bar open.
