runing 3scope cards on a dual core pc carillon audio
A space for learning and studying the Scope environment and music-making in general.
Hydero
Post by Hydero »
:cry: Hi there and welcome to a new year my name is Hydero Mayanja
am having problems with my scope cards (i think)
the cards stops working after a certain time 30 to 45 min and
then i will have to restart.
my set up is a carliion dual core audio pc runing windows xp home.
please help!
erminardi
Post by erminardi »
Check the heat issue into your Carillon rack case.
Carillon PC are quiet but, for this reason, often hot inside (low RPM fan, less fresh air in/out windows).
3 Scope cards in a rack case are maybe too much for a sytem without any adjuntive coolinf fan.
start/run "winmsd"/hardware resources/conflicts-sharing.
is the scope card on the list anywhere? if so, what exactly is it sharing with?
irrelevance
Post by irrelevance »
If it is a heat issue you can unscrew the four bolts at the front and then remove the blanking plate IF your not using the space for anything of course.
Mike Goodwin
Re:
Post by Mike Goodwin »
garyb wrote:start/run "winmsd"/hardware resources/conflicts-sharing.
What a fantastic command! Thanks for sharing.
Neutron
Re: runing 3scope cards on a dual core pc carillon audio
Post by Neutron »
I had the same issue long time ago on my first rack's. Depending on which mobo you have these can be a lifsaver for multiple full length cards.
I had 5 slots filled w/ 3 Scopes, and 2 of these. Way back in the Server Works Chipset days.
